AIR-AP2802I-E-K9 APs PoE diffrences
Moudar
Hi!
We are running a 5520 WLC and we have got many different AP models running.
We have many AIR-AP2802I-E-K9 APs that are running in different ways, meaning some are running  by PoE switch and some are running with a Power injectors.
Some PoE switches we have can only PoE and not PoE+, example is SG-300 switches.
When i check the power consumption that the AIR-AP2802I-E-K9 APs are using on the SG-300 switches i see that the AIR-AP2802I-E-K9 are only using 9.5 watts.
When these APs are using a power injectors then they use about 25 watts!
What is the practical difference between 9.5 and 25 watts?
I did some Googling and find that the antennas number on an AP maybe affected with low wattage! is that right?
How and where to see the difference?
AIR-AP2802I-E-K9 model is 4x4 do they work like 1x1 with low wattage? where can i show this ?
We have thousands of laptops that are 2x2 so 1x1  is bad i think !
Same is right with APs like 1850 model!
Another question is about Clientlink 4.0!
When i check AIR-AP2802I-E-K9 i see that legacy beamforming is disabled, how to show that Clientlink 4.0 is enabled on AIR-AP2802I-E-K9 model?
15 Replies 15
Mark Elsen
                             >....What is the practical difference between 9.5 and 25 watts?
  - You could for instance when one of these AP's using 9.5 watts (only) , connect to it just after it has booted , and issue
the command show logging , watch for messages related to power and or impact for 9.5 watts being available (only)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 - For ClientLink question , check if this thread can provide hints : https://community.cisco.com/t5/wireless/need-to-enable-client-link-feature/td-p/2709340
 M.
       Beauty and terror
      Just keep going
       No feeling is final
The link is old ‎08-05-2015
I think Clientlink 4.0 was not there
When these APs are using a power injectors then they use about 25 watts!"
This AP model requires at least 15.4W. You can check the doc attached.  With 9.5 watts chances are they did not turn the radios on. Or turn on 2.4ghz on.
"What is the practical difference between 9.5 and 25 watts?"
The different is that using 9.5 you does not meet the minimum requirement to this AP to work properly. And using 25 you are above the requirement, which is good. AP will negociate, through CDP or LLDP, the power it needs exactly.
We have thousands of laptops that are 2x2 so 1x1 is bad i think !"
That´s right but I dont belive is possible to see the difference. The AP has its power requirement and you need to attend it. If the power requirement is attended, it will hav full functionality inclusing all the antennas.
"When i check AIR-AP2802I-E-K9 i see that legacy beamforming is disabled, how to show that Clientlink 4.0 is enabled on AIR-AP2802I-E-K9 model?"
You can see it on the WLC cli:
(WLC1) >show 802.11a
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Enabled
Or per AP:
show ap config 802.11a "AP!
Phy OFDM parameters
Configuration ............................. AUTOMATIC
Current Channel ........................... 40
Extension Channel ......................... NONE
Channel Width.............................. 20 Mhz
Allowed Channel List....................... 36,40,44,48,52,56,60,64,149,153,157,161,165
TI Threshold .............................. -50
Legacy Tx Beamforming Configuration ....... AUTOMATIC
Legacy Tx Beamforming ..................... ENABLED
On the 2802 AP model the WLC says:
Legacy Tx Beamforming ..................... DISABLED
I don't know if this is also  Clientlink 4.0, but when i try to enable it i get:
(Cisco Controller) config>802.11a beamforming ap "APname" enable
Slot not disabled.
Probably you need to disable radios first before enabling the feature. Try to shud down the AP radios first and try to enable the feature after.
Perhaps you need to stop the radio first, then execute your commans, and
start the radio again. M.
       Beauty and terror
      Just keep going
       No feeling is final
Moudar
I can now see that all my 2802 and 1852 APs have ClientLink disabled, is there any reason why it is disabled on these by default, while it is enabled by default on older AP models like 2702?
Any answer to first question about the wattage, i did restart one 2802 AP with low wattage but could not see any weird loggs?!
Rich R
If it can run in degraded mode that's usually documented on the data sheet.  Nothing shown for 2800 implying that it MUST have at least POE+ which means it's probably running with radios turned off (that is standard behaviour for low power).
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2800-series-access-points/datasheet-c78-736497.html
Input power requirements
●  802.3at PoE+, Cisco Universal PoE (Cisco UPOE ®)
●  802.3at power injector (AIR-PWRINJ6=)
Power draw
●  22.5W at the PSE (20W at the PD) with all features enabled except for the USB 2.0 port
●  26.5W at the PSE (23W at the PD) with the USB 2.0 port enabled
Compare to 1850 https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1850-series-access-points/datasheet-c78-734256.html
Power draw
●  20.9W
Note: When deployed using a Power over Ethernet (PoE) specification, the power drawn from the power sourcing equipment will be higher by some amount, depending on the length of the interconnecting cable.
Powering options
●  802.3at
●  Enhanced PoE
●  Cisco power injector, AIR-PWRINJ4=
●  Cisco local power supply, AIR-PWR-C=
●  Cisco power injector, AIR-PWRINJ5= ( Note: this injector supports 802.3af only)
●  802.3af
Note: If 802.3af PoE is the source of power, (1) the 1852e 2.4-GHz radio will shift to 2x3 from 3x4, (2) The USB port and AUX Ethernet port are disabled on both the 1852i and 1852e.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Is there any command that shows how many radios are used?
A command that shows if 2x3 or 3x4 are used!
JPavonM
Have you checked your SG300 is a PP model? P-only models do not support PoE+ but only 802.3af.
Check the output from one of my SG300-10PP switches, showing AP3702 connected requiring 16.4Watts but only consuming 7 Watts at the moment.
sg300#sh cdp neighbors de
Device-ID: sg300
Advertisement version: 2
Platform: cisco AIR-CAP3702I-E-K9
Capabilities: TransBridge SourceRouteBridge IGMP
Interface: gi7, Port ID (outgoing port): GigabitEthernet0
Holdtime: 141
Version: Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JPJ7, RELEASE SOFTWARE (fc1)
Copyright (
Duplex: full
Power drawn: 16800 milliwatts
SysObjectID: 0.0
Primary Management Address: IP x.y.z.1,
Addresses:
IP x.y.z.1
IPv6 (link-local)
sg300#sh power inline
Port based power-limit mode
Inrush Test: Enable
Legacy Mode: Enable
Unit Power Nominal Power Consumed Power Usage Threshold Traps Temp (C)
1 On 62 Watts 7 Watts (11%) 95 Disable 58
Jesus
What i have is SG350-10MP
Don't have Show cdp ne details! only sh cdp ne
Version: 2.5.0.83
The question is what happens when using low wattage? is there any command that shows how many radios are used when using low wattage?
The attached shows my sh power inline
All these APs are 2802 model
From that screenshot you can see 16.8 Watt requested and only 6.8 Watt been used at the moment.
That matches 802.3af standard:
– Maximum 16.80 W at the PSE.
So you AP is not receiving PoE+ budget so it will behave weird, as Cisco does not support this scenario to disable radio chains if less power is received.
But Catalyst APs reduces radio chains or even disable radios if less power is received.
We have already ordered about 150 Catalyst 9120 APs.
Do you mean that this model will not work at all if the PoE is not PoE+?
