air-br1310g-e-k9-r coaxial power injectors cables
miroslaw len
hello,
I have found one incomplete air-br1310g-e-k9-r AP in my office, would like to test it, but I would like to know if I think properly - I need 2 standard RG6 cable - 75OHM with F plugs fitted on both end to send ethernet signal directly from power injector to AP?
Thank you for any replies
Saurav Lodh
Level 7
Level 7
Yes dual RG-6 Coax Cable ( Ethernet uplink form Power injector)
But which cable should I use? Can I use Tv/video 75 Ohm cable?
Yes use 75 Ohm cable.
