06-13-2017 05:50 AM - edited 07-05-2021 07:11 AM
we want to connect a aircap1532E access point over poe. The distance is between 90 to 93 meters. Is this possible for poe- and packet quality?
Hubert
Solved! Go to Solution.
06-13-2017 06:39 AM
End to end support is 100 meters using the approved PoE injector for the 15xx.
Here is a link for reference:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1530/installation/guide/1530hig/1530_ch2.html#pgfId-1074449
-Scott
06-13-2017 06:39 AM
-Scott
06-13-2017 09:46 PM
Many thanks for the answer Scott.
Hubert
