AIR-CAP1532I-E-K9 supported with 9800-40 Controller
hamzaghazi
Hi everyone,
Is AIR-CAP1532I-E-K9 supported with 9800-40 Controller. Do we have a workaround to to connect it to the controller or it is not supported at all?
You find answers to questions like these on the Cisco Wireless Solutions Software Compatibility Matrix. And it seems that you are out of luck with this AP.
Leo Laohoo
1532 last firmware support is 8.10.X.X.
Arshad Safrulla
Not supported at all. You can refer to the release notes of 9800 IOS-XE code releases to check the supported AP's.
Starting from 17.4.X support for Wave1 AP's dropped as well. (x700 series AP's)
