AIR-CAP1602i-E-K9
al_the_al
i have recently bought a AIR-CAP1602i-E-K9 and a AIR-SAP1602i-E-K9. I could connect to controller with serial but login and password don't match (admin/admin). I could not connect to it by web (routeur DHCP on the lan), IP change very quickly.
I don't know what to do.
I have no wireless lan for moment and i want to build a little one with them.
6 Replies 6
Leo Laohoo
Username/Password:  Cisco/Cisco
ok, thanks, i could enter with this login/password.
I want to assign an IP to the controller now but i not really good with cisco
Could you tell me the instructions so that i could configure it with werb interface
thanks
Please rate useful replies. Also, mark correct answers as "answered".
Check here about the initial config wizard:
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_gettingstarted.html#wp1189034
Amjad
Rating useful replies is more useful than saying "Thank you"
AIR-CAP1602i-E-K9
If you want to use the APs as autonomous, you'll need to convert this one from controller-based IOS to autonomous IOS.
yes but i can't go on the web interface for moment. Ip always renew
