Android 4.1 tablet not connecting to Aironet 1140
william.espejo
Hello community, I am having an issue with my Android Tablet running 4.1 (Jelly Bean). It is able to the SSID, but when I try to connect - it stays connecting and then says saved, and never connects, as it does not pick up an IP address. I updated the firmware on the Aironet 1140 due to my Windows 8 pc's not connecting as well, it solved my Windows 8 problem, just not my Android Tablet problem. My Ipads do work. Just any android device I connect...
Anyone, ran into this issue that can assist?
Thanks in advance.
Amjad Abdullah
Hello William,
What is the security used on your wireless LAN?
Can you apply this command on your WLC CLI:
show wlan
and post us the output right here?
Reards,
Amjad
Rating useful replies is more useful than saying "Thank you"
