air-Cap1602I-E-K9
infoTechni
I try to configure a air-cap1602i-e-k9. I cann't get connected with the device. I think i haven't the right documatation. with putty i can connect but the loginname and password aren't correct.
Pleas can someone help me?
Rasika Nayanajith
username/password (Cisco/Cisco) should work if they have default configurations.
If no success, you can reset AP to default config using mode button.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4-25d-JA/Configuration/guide/cg_12_4_25d_JA/scg12-4-25d-JA-chap22-trouble.html#wp1058433
Rasika
*** Pls rate all useful responses ***
EvaldasOu
Level 4
Level 4
If Your access point is in CAPWAP (not autonomous) mode, by default You can't use SSH or Telnet to connect.
Do You have wireless LAN controller for CAPWAP AP to connect? If no, check this guide how to convert AP image to autonomous:
https://supportforums.cisco.com/document/57476/lwapp-autonomous-conversion-and-vice-versa-access-points
Default console login, as Rasika said: Cisco / Cisco
Moin Ilyas
Level 4
Level 4
If you'd like to use it as an Autonomous AP, convert it as suggested by EvaldasOu and then refer to the following link:
Configuration Guide for Autonomous Aironet Access Points
