AIR-CAP1602I-T-K9
Hello.
Can I convert a AIR-CAP1602I-T-K9 from controller-based to stand-alone???
Thank you.
5 Replies 5
OF course you can.
Here's the link of the stand-alone image.
http://software.cisco.com/download/release.html?mdfid=284366503&flowid=37523&softwareid=284180979&release=15.2.4-JB5&relind=AVAILABLE&rellifecycle=ED&reltype=latest
do you know how to convert it?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
No, please help me.
Sure no problem.
First you need to download the correct image. You can do it in the previous link.
Console tu AP and write this command: debug capwap console cli. Whit this line you you capwap ap will accept the command conf t
then:
conf t
ip default-gateway X.X.X.X
(I recommend that your computer's ip and the default gateway be the same.)
interface g0
ip address X.X.X.X  x.x.x.x <-- Your subnet mask
no shut
archive download-sw /force-reload /overwrite tftp://X.X.X.X/c1140-k9w7-tar.124-25d.JA.tar
TFTP X.X.X.X = Your ip computer
c1140-k9w7-tar.124-25d.JA.tar= you need to change it for the correct name.
Your computer and your AP have to be in the same network
Example:
My computer address: 10.10.10.1
conf t
ip default-gateway 10.10.10.1
int g0
ip address 10.10.10.102 255.255.255.0
no sh
archive download-sw /force-reload /overwrite tftp://10.10.10.1/c1140-k9w7-tar.124-25d.JA.tar
Thank you d.ordonez.
I will go to try to do this conversion.
Thank you for help me.
You're welcome.
***Please rate the answer if this information was useful***
