AIR-CAP2602E-E-K9
peteris peteris
Community Member
Hello!
How do I configure my AIR-CAP2602E-E-K9? I have to delete everything in it but it seems that all my previous methodes do not work? Is there a tutorial or any instruction to how to do it properly?
Best regards,
Peteris
8 Replies 8
Mark Elsen
          - How do you mean ? This AP can be used as client (CAPWAP) access point only , (connected to a controller)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I want to do a factory reset to it. I have done 30-30-30 reset previously with these AP but don't know why it doesn't work anymore.  I use same cables. Perhaps there's a problem with specific AP?
 - Check if this document can help : https://popravak.wordpress.com/2014/08/26/resetting-cisco-capwaplwap-access-point-to-factory-defaults/
 M.
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP: Macronix Mirrorbit (00C2)
Xmodem file system is available.
flashfs[0]: 70 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 2097664
flashfs[0]: Bytes available: 29900288
flashfs[0]: flashfs fsck took 12 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 78:da:6e:8e:17:88
Ethernet speed is 100 Mb - FULL Duplex
The system is unable to boot automatically because there
are no bootable files.
C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
Compiled Thu 03-Oct-13 03:35 by sdcunha
ap:
reset
Are you sure you want to reset the system (y/n)?y
System resetting...
flash is writable
ap:
I have problem like this. It does not reset the device and does not go where I can use default USERNAME and PASSWORD
 - Looks like it currently has no (valid) software installed , look at this procedure : https://community.cisco.com/t5/wireless-mobility-knowledge-base/access-point-rommon-recovery-ap-prompt-recovery-example/ta-p/3119495 , but you will need to change the image according to an image that is compatible with your access point (and or make sure you have that available first) ,
 M.
I want to do a factory reset, but when I do necessary steps it goes to ap mode all the time and I can't use default USERNAME and PASSWORD to check if the factory reset has occurred.
Rich R
@peteris peteris I think you're missing the point of what @Sandeep Choudhary and @Mark Elsen are trying to explain to you!
You have completely wiped the flash of your AP (or the flash got corrupted) so there is no IOS, so your AP cannot boot so it starts in ROMMON mode.  Before you can do anything else you must INSTALL an IOS so that the AP has an operating system to boot off.  Follow the instructions in the link provided already.
Another method: https://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
FYI: https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/99763-reset-lwappconfig-lap.html
See https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213317-understanding-various-ap-ios-flash-corru.html in case your AP flash got corrupted.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
