06-23-2021 10:25 AM - edited 07-02-2021 09:36 PM
Good day, I converted an AIR-CAP2702I-E-K9 to an autonomous AP. Unfortunately I can't get the GUI in my browser. Here is the boot log:
IOS Bootloader - Starting system. flash is writable Antigua Board 40MB format Tide XL MB - 40MB of flash Xmodem file system is available. flashfs[0]: 311 files, 14 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 41158656 flashfs[0]: Bytes used: 29484032 flashfs[0]: Bytes available: 11674624 flashfs[0]: flashfs fsck took 11 seconds. Base Ethernet MAC address: XXXXXX8 Ethernet speed is 1000 Mb - FULL Duplex Loading "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-mx.153-3.JPK"...######################### File "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-mx.153-3.JPK" uncompressed and installed, entry point: 0x2003000 executing... Secondary Bootloader - Starting system. Antigua Board Pre-Pilot 40MB format Tide XL MB - 40MB of flash Xmodem file system is available. flashfs[0]: 311 files, 14 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 41158656 flashfs[0]: Bytes used: 29484032 flashfs[0]: Bytes available: 11674624 flashfs[0]: flashfs fsck took 11 seconds. flashfs[1]: 0 files, 1 directories flashfs[1]: 0 orphaned files, 0 orphaned directories flashfs[1]: Total bytes: 12257280 flashfs[1]: Bytes used: 1024 flashfs[1]: Bytes available: 12256256 flashfs[1]: flashfs fsck took 1 seconds. Base Ethernet MAC address:XXXXXX Boot CMD: 'boot flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK;flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK' Loading "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK"...########################################### File "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK" uncompressed and installed, entry point: 0x1003000 executing... Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 Cisco IOS Software, C2700 Software (AP3G2-K9W7-M), Version 15.3(3)JPK, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2020 by Cisco Systems, Inc. Compiled Tue 24-Nov-20 03:58 by prod_rel_team Antigua Board Pre-Pilot 40MB format Tide XL MB - 40MB of flash Initializing flashfs... flashfs[2]: 311 files, 14 directories flashfs[2]: 0 orphaned files, 0 orphaned directories flashfs[2]: Total bytes: 40900608 flashfs[2]: Bytes used: 29484032 flashfs[2]: Bytes available: 11416576 flashfs[2]: flashfs fsck took 12 seconds. flashfs[2]: Initialization complete. flashfs[4]: 0 files, 1 directories flashfs[4]: 0 orphaned files, 0 orphaned directories flashfs[4]: Total bytes: 11999232 flashfs[4]: Bytes used: 1024 flashfs[4]: Bytes available: 11998208 flashfs[4]: flashfs fsck took 1 seconds. flashfs[4]: Initialization complete. Copying radio files from flash: to ram: Copy in progress...CCCCC Copy in progress...CCC Copy in progress...CCCC Copy in progress...CCCC Copy in progress...CC Copy in progress...CC Copy in progress...CCCC Copy in progress...CC Copy in progress...CCCCCCCC Copy in progress...CCCC Copy in progress...CC Copy in progress...C Uncompressing radio files... ...done Initializing flashfs. Radio0 present 8764 8000 0 A8000000 A8010000 0 Rate table has 650 entries (20 legacy/224 11n/406 11ac) POWER TABLE FILENAME = ram:/U2.bin Radio1 present 8864 8000 0 80000000 80100000 4 POWER TABLE FILENAME = ram:/U5.bin Radio2 not present 0 0 0 0 0 8 This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-SAP2702I-E-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory. Processor board ID FCW1950NNBQ PowerPC CPU at 800Mhz, revision number 0x2151 Last reset from power-on 1 Gigabit Ethernet interface 2 802.11 Radios 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: XXXX Part Number : 73-15XXXXXX PCB Serial Number : FOC1XXXXX01 Top Assembly Serial Number : FCWXXXXX Top Revision Number : A0 Product/Model Number : AIR-CAP2702I-E-K9 System is configured with default enable secret.Please change it before enabling HTTP Server Press RETURN to get started! *Mar 1 00:00:17.483: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15) *Mar 1 00:00:23.631: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4) *Mar 1 00:00:23.747: loading Power Tables from ram:/U2.bin. Class = E *Mar 1 00:00:23.747: record size of 3ss: 1168 read_ptr: 490F8EE *Mar 1 00:00:28.943: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4) *Mar 1 00:00:28.991: loading Power Tables from ram:/U5.bin. Class = E *Mar 1 00:00:29.023: record size of vht: 2904 read_ptr: 490F8EE *Mar 1 00:00:29.083: Starting Ethernet promiscuous mode *Mar 1 00:00:29.159: SCHED: Ethernet Bridge Process: install watched boolean System Initialized(48F7B30), os:1 ah:0 *Mar 1 00:00:31.267: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up *Mar 1 00:00:31.267: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up *Mar 1 00:00:31.767: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10 *Mar 1 00:00:31.771: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10 *Mar 1 00:00:31.771: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 27 *Mar 1 00:00:31.775: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 27 *Mar 1 00:00:31.787: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down *Mar 1 00:00:31.787: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down *Mar 1 00:00:31.799: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C2700 Software (AP3G2-K9W7-M), Version 15.3(3)JPK, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2020 by Cisco Systems, Inc. Compiled Tue 24-Nov-20 03:58 by prod_rel_team *Mar 1 00:00:31.843: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized(48F7B30) *Mar 1 00:00:31.843: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue(48EA238), os:0 ah:0 *Mar 1 00:00:31.843: No configuration in NVRAM..Auto Install initiated.. *Mar 1 00:00:32.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down *Mar 1 00:00:32.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down *Mar 1 00:00:32.783: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up *Mar 1 00:00:32.787: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down *Mar 1 00:00:32.787: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down *Mar 1 00:00:36.447: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (0-0) *Mar 1 00:00:36.447: DPAA Initialization Complete *Mar 1 00:00:36.447: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited *Mar 1 00:00:37.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up *Mar 1 00:00:39.859: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.178.207, mask 255.255.255.0, hostname ap *Mar 1 00:00:46.279: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10 *Mar 1 00:00:46.279: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10 *Mar 1 00:00:46.279: %CDP_PD-4-POWER_OK: 15.4 W power - INJECTOR_CONFIGURED_ON_SOURCE inline power source *Mar 1 00:00:48.279: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
Greats
Dirk Meyer
06-23-2021 10:33 AM - edited 06-23-2021 10:35 AM
When you convert to autonomous, you have to go through the cli to do the initial configuration and to setup http(s) access. Search the internet for "Cisco capwap to autonomous" and look at some blogs and docs to show the initial configuration.
Also search "cisco autonomous ap http access"
06-23-2021 01:33 PM
BVI1 192.168.10.123 YES manual down down
Dot11Radio0 unassigned YES unset administratively down down
Dot11Radio1 unassigned YES unset administratively down down
GigabitEthernet0 unassigned YES TFTP up down
GigabitEthernet1 unassigned YES TFTP administratively down down
al ot of hours later i fund this out the is no manual to get an http access to the ap.
mostly there are wrong or not compledet little therms. i thouht it was easyer. my mistake
06-24-2021 06:20 AM
Also beware of using the GUI on recent autonomous IOS. If you search the forums you'll find lots of posts about some parts of the GUI which are broken.
End of SW Maintenance Releases Date was 29 April 2020 so Cisco no longer test these software releases so you can expect to find things broken which will never be fixed.
If you want to use the latest releases you may need to stick to using CLI not GUI.
If you want to use GUI you might need to use older releases which have security vulnerabilities (which are still being fixed up till 29 April 2022 in the later releases).
06-24-2021 08:04 AM
version_suffix: k9w7-.152-4.JB6
version_directory: ap3g2-k9w7-mx.152-4.JB6
image_name: ap3g2-k9w7-mx.152-4.JB6
ios_image_file_size: 215552
total_image_file_size: 15135232
image_feature: WIRELESS LAN|LWAPP
image_family: AP3G2
system_type: 0x9b
ws_management_version: 7.6.100.0
info_end:
this is the odelst version i found . it`s from 2014
version_suffix: k9w7-.153-3.JPK1
version_directory: ap3g2-k9w7-mx.153-3.JPK1
image_name: ap3g2-k9w7-mx.153-3.JPK1
ios_image_file_size: 10732032
total_image_file_size: 13998592
image_family: AP3G2
system_type: 0x9b
ws_management_version: 17.5.1.12
info_end:
the newes,t date 03/21
wich version shoud i use?
the oldest and the newest i found dosen`t work
06-24-2021 09:09 AM
Have you successfully converted the ap and are also able to ssh to the ip of the ap? This will determine also if you have done the initial configuration properly or not. Then the other docs that show you how to allow http and also configure the unit can be used. Like what was mentioned also, the GUI can be problematic especially that its end of support. Majority of folks configure these autonomous ap's from the CLI.
Also the latest image I see on the downloads page is ap3g2-k9w7-tar.153-3.JPK1.tar which you have.
06-24-2021 10:38 AM
i flashed the newes versoin . and restart the ap. i have only the cli. i don`t get a ssh connection . i can`t find out the current ip of the ap.
i àm an absolut beginner.
yes the ap3g2-k9w7-tar.153-3.JPK1.tar is the latest image i have
06-24-2021 02:22 PM
from the console, you should be able to login using Cisco/Cisco and also you should see what ip the ap receives from dhcp. When you are consoled in.
06-25-2021 12:42 AM
"show ip interface brief"
If your next question is how do I configure it?
You can find plenty of example configs for autonomous APs if you search.
You ideally need to be familiar with the basics of Cisco IOS and AP configuration to understand what you're doing.
06-25-2021 03:22 PM
at first i was boered abaut your answers but now i am happy. you give me usefull ttipps. but i hadto feind out what you mean with then.
that`s the right way to learn something new. thank you very much.
https runs on all my ap`s. now i have to find how to configure then.
all ap`s has the aktuelly images.
06-25-2021 03:55 PM
It is the right way to learn. It’s very hard to tell folks what they need to do when there are many different ways things fail. Even with new equipment, folks would research on the forums, reach out to Cisco folks or other engineers, search blogs and test.
