04-19-2015 11:55 PM - edited 07-05-2021 02:58 AM
Hi there,
I'm facing a strange issue as the CAPWAP AP is reporting problems while trying to associate the controller.
These are the steps:
*spamApTask3: Apr 17 13:34:34.370: a0:ec:f9:26:91:c4 Discovery Response sent to u.v.x.y:26909
*spamApTask0: Apr 17 13:34:34.373: a0:ec:f9:26:91:c4 Received LWAPP DISCOVERY REQUEST to 10:05:ca:be:f7:a9 on port '4'
*spamApTask0: Apr 17 13:34:34.373: a0:ec:f9:26:91:c4 Discarding discovery request in LWAPP from AP supporting CAPWAP
Attached you can find the captures from both AP console and controller.
04-20-2015 12:41 AM
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. AP: sh version
The time/date on the WLC is incorrect.
04-20-2015 02:16 AM
APa0ec.f926.91c4#sh version
Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 15-Aug-14 12:27 by prod_rel_team
ROM: Bootstrap program is C2700 boot loader
BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m, RELEASE SOFTWARE (fc2)
APa0ec.f926.91c4 uptime is 46 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2702I-E-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FCW1847NH67
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.72.236
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A0:EC:F9:26:91:C4
Part Number : 73-15824-03
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC184672B9
Top Assembly Part Number : 068-100379-01
Top Assembly Serial Number : FCW1847NH67
Top Revision Number : A0
Product/Model Number : AIR-CAP2702I-E-K9
Configuration register is 0xF
And for the controller:
(wcontrollerbe1.bsch) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.121.0
RTOS Version..................................... 7.4.121.0
Bootloader Version............................... 8.0.100.0
Emergency Image Version.......................... 8.0.100.0
Build Type....................................... DATA + WPS
System Name...................................... wcontrollerbe1
System Location.................................. CPD Este
System Contact................................... Red Datos
System ObjectID.................................. 1.3.6.1.4.1.9.1.1615
Redundancy Mode.................................. Disabled
IP Address....................................... a.b.c.d
System Up Time................................... 35 days 16 hrs 20 mins 56 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... ES - Spain
Operating Environment............................ Commercial (10 to 35 C)
04-20-2015 04:06 AM
As per your ouput you have WLC software version:
and for 2702I AP you need at-least 7.6.120.0 version to join to WLC.
See the compatibility matrix.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Upgrade your WLC software and then try again.
Don't forget to rate helpful posts
04-20-2015 05:44 AM
I was looking only the Bootloader versión and I saw it was rigth. My bad.
04-20-2015 04:24 AM
Upload your WLC firmware to the latest 7.6.X firmware and the AP should join.
