AIR CAP2702I-E-K9 to Autonomous Mode
AxL1971
We are currently replacing all our AP's with Meraki MR56, therefore I want to use the 2702I at home
They are currently setup in lightweight mode and connect to a WLC - I have read many articles on setting them up as autonomous mode but get different methods
I have access to the USB console cable so will use the CLI method
What is the trusted method to convert these.
Initially I want to clear current settings then flash the autonomouse firmware
5 Replies 5
marce1000
   - What do you mean by 'trusted method' ?
 M.
Arshad Safrulla
Below are some goof articles which explains the conversion process
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
https://www.speaknetworks.com/converting-cisco-wireless-access-point-lightweight-mode-autonomous-mode-vice-versa/
You need to download the Cisco Autonous AP image from Cisco in-order to convert it.
Software Download - Cisco Systems
AxL1971
lt sorted now
did notioe when I tried to create another SSID on Radio 0 it did not allow me to do this
what command do I use to allow me to have 2 SSID On Radio 0
 - Following GUI and or creating multiple SSID's/WLAN's should work. What error do you get ?. And or post screenshot (e.g.)
 M.
