AIR-CAP3501i - default username and password?
ddepker
I have searched everywhere for the default login to the CAP3501i and have found nothing.
Anyone able to provide this info?
5 Replies 5
Leo Laohoo
Cisco/Cisco
So I hard reset the AP:
unplug
press mode button
plug in POE
hold mode button for 10 seconds (held 10 and then 180 seconds, to be safe)
I have tried
Cisco/Cisco
cisco/cisco
admin/admin
admin/password
 - Post boot process after you tried the hard reset.
 M.
This is what happened when i booted up after holding down the mode button for 66 seconds.
it tries to access a file here, but not sure why 255
tftp://255.255.255.255/ap3g1-k9w7-tar.default
User Access Verification
Username: Cisco
Password:
% Authentication failed
Username:
Not in Bound state.
*Mar  2 12:18:20.399: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP ad                       dress is not assigned or assigned IP is wrong. Renewing DHCP IP.
r WRDTR,CLKTR: 0x8200083f 0x40000000
r RQDC ,RFDC : 0x80000033 0x00000217
using  eeprom values
using MCNG ddr static values from serial eeprom
ddr init done
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x8200083f, 0x40000000
RQDC, RFDC : 0x80000033, 0x00000217
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is NOT up.
Check PCIe signals to radio, re-seat radio.
PCIE1 port 1 not initialized
64bit PCIE devices
PCIEx: initialization done
flashfs[0]: 46 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31739904
flashfs[0]: Bytes used: 12608512
flashfs[0]: Bytes available: 19131392
flashfs[0]: flashfs fsck took 10 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 00:07:7d:f8:8b:60
Ethernet speed is 1000 Mb - FULL duplex
button is pressed, wait for button to be released...
button pressed for 66 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g1-k9w7                       -tar.default
examining image...
%Error opening tftp://255.255.255.255/ap3g1-k9w7-tar.default (connection timed out)
it went to ap:
so I entered boot
ap: boot
Loading "flash:/ap3g1-k9w8-mx.153-3.JC14/ap3g1-k9w8-mx.153-3.JC14"...###############
File "flash:/ap3g1-k9w8-mx.153-3.JC14/ap3g1-k9w8-mx.153-3.JC14" uncompressed and installed, entry point: 0x4000
executing...
enet halted
IOS Secondary Bootloader - Starting system.
PCIE0: link is up.
Radio 1 : Vendor 0x11AB, Device 0x8324
64bit PCIE devices
flashfs[0]: 45 files, 9 directories
Creating Test Kernel diagnostic commands
Radio 0 : Vendor 0x11AB, Device 0x8324
Radio 1 : Vendor 0x6AF7, Device 0x5E5F
Radio 2 : Vendor 0x8673, Device 0x79F5
Radio 3 : Vendor 0x1086, Device 0x7840
******** AUTOMATIC DDR CALIBRATION UPGRADE LOGIC *********
=== 1. Is original FCS bootloader in BS:? If not, skip upgrade ===
---> original FCS bootloader not detected -- skip upgrade
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g1-k9w8-mx.153-3.JC14/ap3g1-k9w8-xx.153-3.JC14'
Loading "flash:/ap3g1-k9w8-mx.153-3.JC14/ap3g1-k9w8-xx.153-3.JC14"...####################################
File "flash:/ap3g1-k9w8-mx.153-3.JC14/ap3g1-k9w8-xx.153-3.JC14" uncompressed and installed, entry point: 0x100000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 15.3(3)JC14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sun 29-Oct-17 16:49 by prod_rel_team
Initializing flashfs...
flashfs[2]: 45 files, 9 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31481856
flashfs[2]: Bytes used: 12608512
flashfs[2]: Bytes available: 18873344
flashfs[2]: flashfs fsck took 10 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8364B 8000 B8020000 0 B8030000 10
Rate table has 300 entries (16 legacy/64 11n/220 11ac)
POWER TABLE FILENAME = ram:/Z2.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3501I-A-K9 (PowerPC460exr) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1531KC98
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 8.2.166.0
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:7D:F8:8B:60
Part Number : 73-12175-05
PCB Serial Number : FOC15234CCG
Top Assembly Part Number : 800-32902-01
Top Assembly Serial Number : FTX1531KC98
Top Revision Number : A0
Product/Model Number : AIR-CAP3501I-A-K9
% Please define a domain-name first.
