09-18-2017 06:35 AM - edited 07-05-2021 07:39 AM
Hello Guys
i have this AP model , AIR-CAP3502I-A-K9 , i am console to it , i dont have the option to get into #prompt to enter the commands manulay ,it always ask for DHCP
how to do that>>>
thanks
09-18-2017 06:50 AM
DHCP requests - it is ok for this AP.
Can you enter username and password?
If you press "enter", will you see "username" promt?
What about console settings?
Bits per sec : 9600 Data bits : 8 Parity : none Stop bits : 1 Flow control : none
09-18-2017 06:58 AM
1)the secureCRT settings is same
2)i am not able to reach username/password
3)after i update the software for 8 from the wlc , i m now getting the below errors
*Sep 18 13:53:44.569: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 18 13:53:45.557: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 18 13:53:45.563: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 18 13:53:45.585: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 18 13:53:45.592: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Sep 18 13:53:45.598: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Sep 18 13:53:46.586: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 18 13:53:46.592: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 18 13:53:46.614: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Sep 18 13:53:47.614: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 18 13:53:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.10.1 peer_port: 5246
*Sep 18 13:53:54.264: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.10.1 peer_port: 5246
*Sep 18 13:53:54.267: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.10.1
*Sep 18 13:53:55.365: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.10.10.1
*Sep 18 13:53:55.365: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.10.1:5246
*Sep 18 13:53:55.421: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Sep 18 13:53:55.453: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
*Sep 18 13:53:55.456: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Sep 18 13:53:55.456: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep 18 13:53:55.459: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Sep 18 13:53:55.494: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 18 13:53:56.456: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 18 13:53:56.478: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep 18 13:53:56.485: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 18 13:53:57.472: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 18 13:53:57.479: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 18 13:53:57.501: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 18 13:53:57.507: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Sep 18 13:53:57.513: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Sep 18 13:53:58.501: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 18 13:53:58.507: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 18 13:53:58.529: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Sep 18 13:53:59.530: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 18 13:54:05.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.10.1 peer_port: 5246
*Sep 18 13:54:05.267: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.10.1 peer_port: 5246
*Sep 18 13:54:05.267: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.10.1
*Sep 18 13:54:05.456: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.10.10.1
*Sep 18 13:54:05.456: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.10.1:5246
*Sep 18 13:54:05.509: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Sep 18 13:54:05.541: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
*Sep 18 13:54:05.544: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Sep 18 13:54:05.544: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep 18 13:54:06.544: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 18 13:54:06.566: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep 18 13:54:06.572: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 18 13:54:07.560: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Sep 18 13:54:07.566: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 18 13:54:07.588: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 18 13:54:07.595: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Sep 18 13:54:07.601: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Sep 18 13:54:08.589: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 18 13:54:08.595: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Sep 18 13:54:08.617: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
09-18-2017 07:06 AM
the console settings are okay
2)i am not able to reach the username/password
3)the AP joined the WLC , i have performed software upgrade from the WLC , after update i m getting the below msgs
how to solve that
09-18-2017 07:30 AM
i am not able to get into username/password promot
