AIR-CAP3502I-E-K9 does not join preferred controller
vladakoci
Level 4
Level 4
I have an AIR-CAP3502I-E-K9 AP that is configured for two WLAN controllers with preferred order. However the AP does not join the primary controller, but uses the secondary one instead. I have a bunch of these AIR-CAP3502I-E-K9s , majority work fine, but three of them not.
I have tried commands according to
https://supportforums.cisco.com/docs/DOC-24917
In the controller's GUI  the order is properly configured. I also tried to use 'Clear All Config" option on the controller and configured the AP from the scratch, but this did not help.
Here is what I have
XXXX#sh capwap client config
configMagicMark         0xF1E2D3C4
chkSumV2                30883
chkSumV1                1073
swVer                   7.2.111.3
adminState              ADMIN_ENABLED(1)
name                    XXXX
location                YYYY
group name
mwarName                ZZZZ1
mwarIPAddress           192.168.1.1
mwarName                ZZZZ2
mwarIPAddress           192.168.1.2
mwarName
mwarIPAddress           0.0.0.0
ssh status              Enabled
Telnet status           Enabled
numOfSlots              2
spamRebootOnAssert      1
spamStatTimer           180
randSeed                0xBAC2
transport               SPAM_TRANSPORT_L3(2)
transportCfg            SPAM_TRANSPORT_DEFAULT(0)
initialisation          SPAM_PRODUCTION_DISCOVERY(1)
ApMode                  Local
ApSubMode               Not Configured
AP Rogue Detection Mode Enabled
OfficeExtend AP         [0] Disabled
OfficeExtend AP JoinMode[0] Standard
Discovery Timer         10 secs
Heart Beat Timer        30 secs
Led State Enabled       1
Primed Interval         0
AP ILP Pre-Standard Switch Support Disabled
AP Power Injector Disabled
Infrastructure MFP validation Disabled
Configured Switch 1 Addr 192.168.1.2
Configured Switch 2 Addr 192.168.1.1
non-occupancy channels:
Ethernet (Duplex/Speed) auto/auto
*Mar  1 00:14:23.001: %CAPWAP-3-ERRORLOG: Selected MWAR 'ZZZZ2'(index 1).
*Mar  1 00:14:23.001: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 22 12:21:57.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Aug 22 12:21:57.581: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Aug 22 12:21:57.581: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
My primary one is 192.168.1.1 and secondary is 192.168.1.2, but the AP joins always the secondary one.
The lines above
seem to be suspicious, I would expect the reverse order, but do not know how the code did it.
The only guess is that in the very beginning the AP joined 192.168.1.2, and this was the controller I configured the AP initially from. The AP seems to maybe somehow remember this.
OS version is
swVer                   7.2.111.3
Vlad
13 Replies 13
Scott Fella
Do you have the mobility group up between the two wlcs and is the primary and secondary configured with the host name if the wlc. It is case sensitive. Do you have any APs connected to the other one? Do you have security enabled to prevent APs from joining the other wlc.
-Scott
Yes, there is a mobility group configured and active between the two controllers.
The primary and secondary controllers are configured in AP HA tab with both hostnames and IP addresses. The host names are correct.
I have 12 APs working fine, means that are joined with the primary controller, and have 3 APs that are joined with the secondary and not able to push them to join the primary one. All APs were configured in the same way - initially joined the secondary controller ( because only there I had the OS version compatible with C3602 at that time ) where I used GUI to configure the HA for APs. As I am lazy I configured the primary and secondary names and IPs through a copy and paste way, so there is no typo in the HA names or IPs.
I do not have any security enabled to prevent APs from joining other WLCs. Also in the log on the AP I can see it does not try to join the primary one, it goes directly to the secondary one.
There is also DHCP configured for the APs on our core switch, the same way for all APs
ip dhcp pool XXXX
   host 192.168.1.21 255.255.255.0
   client-identifier 01e0.5fb9.a800.7f
   default-router 192.168.1.254
   option 43 ip 192.168.1.1 192.168.1.2
   lease 30
Option 43 and DNS is only for initial join. If the apps already joined you have to configure each ap to point to the WLC you want it to join.
-Scott
Yes, this is what I am trying all the time - configure the AP to point to the WLCs I want it to join.
Firstly I did through GUI, did not work.
Secondly I  used 'Clear All Config" option on the controller and configured the AP from the scratch through GUI, did not work.
Thirdly I tried through command line on the AP, did not work.
I used these commands
XXXX#capwap ap  primary-base ZZZZ1 192.168.1.1
XXXX#capwap ap  secondary-base ZZZZ2 192.168.1.2
chkSumV2                30883
chkSumV1                1072
swVer                   7.2.111.3
name                    XXXX
location                YYYY
group name
mwarName                ZZZZ1
mwarName                ZZZZ2
mwarName
ssh status              Enabled
numOfSlots              2
spamStatTimer           180
randSeed                0xBAC2
ApMode                  Local
Led State Enabled       1
Primed Interval         0
XXXX#sh log
Syslog logging: enabled (1 messages dropped, 8 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 61 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 67 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level emergencies, 0 message lines logged
        Logging to 255.255.255.255(global) (udp port 514, audit disabled,  link down), 0 message lines logged, xml disabled,
               filtering disabled
Log Buffer (1048576 bytes):
*Mar  1 00:00:09.424: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.434: *** CRASH_LOG = YES
*Mar  1 00:00:09.434: 64bit PCIE devicesSecurity Core found.
Base Ethernet MAC address: E0:5F:B9:A8:00:7F
*Mar  1 00:00:12.482: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:13.731: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:13.797: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:16.996: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:17.052: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:17.068:  status of voice_diag_test from WLC is false
*Mar  1 00:00:19.182: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 12.4(25e)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 14-Sep-12 19:13 by prod_rel_team
*Mar  1 00:00:19.182: %SNMP-5-COLDSTART: SNMP agent on host XXXX is undergoing a cold start
*Mar  1 00:13:33.342: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:13:33.342: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:13:33.493:  status of voice_diag_test from WLC is false
*Mar  1 00:13:33.632: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:13:33.956: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:13:34.343: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:13:34.343: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:13:36.029: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:13:41.484: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.21, mask 255.255.255.0, hostname XXXX
*Mar  1 00:13:51.981: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:14:01.997: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:14:06.099: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:14:07.190: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:14:08.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:14:08.288: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:14:09.289: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:14:11.000: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Aug 23 06:07:13.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Aug 23 06:07:13.578: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Aug 23 06:07:13.578: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Aug 23 06:07:14.025: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Aug 23 06:07:14.091: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Aug 23 06:07:14.094: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller ZZZZ2
*Aug 23 06:07:14.154: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
What I think might be the key to the problem is this
This is not changing no matter what I do.
Vlad
That's not the right command.  Try "capwap ap controller ip address ".
This one I tried in the past as well, did not help me.
XXXX#capwap ap controller ip address 192.168.1.1
chkSumV2                30884
chkSumV1                1071
swVer                   7.2.111.3
name                    XXXX
location                YYYY
group name
mwarName                ZZZZ1
mwarName                ZZZZ2
mwarName
ssh status              Enabled
numOfSlots              2
spamStatTimer           180
randSeed                0xBAC2
ApMode                  Local
Led State Enabled       1
Primed Interval         0
Reboot
XXXX#sh log
    Console logging: level debugging, 60 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 14 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty1(14)
    Buffer logging: level debugging, 66 messages logged, xml disabled,
                    filtering disabled
               filtering disabled
*Mar  1 00:00:09.418: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.430: *** CRASH_LOG = YES
*Mar  1 00:00:09.430: 64bit PCIE devicesSecurity Core found.
*Mar  1 00:00:12.479: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:13.724: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:13.790: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:16.993: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:17.046: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:17.062:  status of voice_diag_test from WLC is false
*Mar  1 00:00:19.179: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:19.179: %SNMP-5-COLDSTART: SNMP agent on host XXXX is undergoing a cold start
*Mar  1 00:13:33.475:  status of voice_diag_test from WLC is false
*Mar  1 00:13:33.613: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:13:33.965: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
--More--
*Aug 23 09:17:08.232: %DOT11-6-DFS_SCAN_COMPLETE: DFS scan complete on frequenc*Mar  1 00:13:41.465: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.21, mask 255.255.255.0, hostname XXXX
*Mar  1 00:13:51.978: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:14:01.994: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:14:06.313: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:14:07.404: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:14:08.405: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:14:08.502: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:14:09.503: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:14:10.997: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:14:22.998: %CAPWAP-3-ERRORLOG: Selected MWAR 'ZZZZ2'(index 1).
*Mar  1 00:14:22.998: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 23 09:16:04.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Aug 23 09:16:04.578: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Aug 23 09:16:04.578: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
ip dhcp pool XXXX
lease 30
The two lines in RED does not make any logic.  So you have assigned the MAC addres (via client-id) to a specific IP address.  You don't necessarily need the 30-day lease time, really.
In regards to your initial problem, I agree with Scott.  Go to the AP and manually set the primary/secondary controllers.
Scott Fella
You need to look at this guide to make sure everything is setup right.
http://www.cisco.com/en/US/docs/wireless/controller/7.3/configuration/guide/b_wlc-cg_chapter_01000.html#ID3096
-Scott
These all are Cisco default values. I am going to open a ticket at Cisco.
Well, finally I realized that the number of APs on the primary controller is on its maximum. That's why the AP did not join the primary controller. There was not a clue in any log file that this could be a license issue.
You typically would see that log on the WLC. We assume when answering a post that this has been checked since we cant see the wlc. At least now I know that I have to quit assuming:).
Thanks for providing the results.
-Scott
Abha Jha
There are many reasons of LWAPP no joining the primary controller:-
Possibly it might have attached to the secondary controller earlier and needs the manual ntervention to join the specific controller..
controller capacity
VLAN issue etc..
