Client Ip address issue
Pravin Pillai
Level 3
Level 3
I have a 1142 AP which is connected to the access switch. I have configured the AP but the problem seems when the client tries to connect to the AP he is not able to connect. I have checked all thr configurations and all the required vlans are allowed on the trunk ports.DHCP is enabled and utilization is below 40%. ALso i am able to ping the helper-address from the AP. I can ping the core switch AP Management Vlan.  The client can see the required SSID.
I tried to run log messages on AP and found messgaes related to autthentication. like deauthenticating station --reason : previous authentication not valid...repeatedly
I believe this is due to mismatch of keys in 802.1x WPA2 authentication. Please let me know in case anything else needs to be ascertained
devils_advocate
Level 11
Level 11
Can you post the AP config without the usernames/passwords etc?
Abha Jha
Its clearly shows the authentication issue...beteen client and AP and radius.
