AIR-CAP3502I run both 2.4Ghz and 5Ghz simultaneously?
Eric Daoust
Can i run both 2.4 and 5ghz at the same time? so my N user's can connect at 300Mpbs on the 5ghz bonded, and my G users can connect to 54Mbps?
Also i ask because of coverage, my 5ghz does not cover as far as the 2.4 so those at the extremity's could at least get G with a good signal
Stephen Rodriguez
you sure can!
just need to configure the SSID under both the radi0 and radio1 interfaces.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
The 5ghz being a higher frequency doesn't travel as far as the 2.4ghz. Like Steve mentioned you can run an SSID on both radios since you have a Lightweight Access Point. This does require a a WLC.
-Scott
or convert it to run aIOS
HTH,
Steve
HTH,
Steve
Here are the conversion links:
Using a TFTP Server to Return to a Previous Release
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
