03-09-2021 12:49 PM - edited 07-05-2021 01:21 PM
I recently converted this from capwap to autonmous successfully using IOS ap3g2-k9w7-xx.153-3.JF10
Thinking that it might be nice not to have the LED illuminating the landing i turned it off in exec mode using the command
ap (config) # LED display off which worked
Now the only problem is it won't turn back on when i send
ap (config) # LED display dim
when you query the command using
ap (config) # LED display ? it only gives the options off or dim
Anybody got any ideas on how to get it back on, short of flashing the whole thing again and setting up from scratch.
Cheers
Graham
Solved! Go to Solution.
03-09-2021 02:45 PM
Hi Graham,
You can simply use "no" in the front of those CLI commands to remove it
AAP1(config)#no led display ?
dim Turn LED display dim.
off Turn LED display off
Rasika
*** Pls rate all useful responses ***
03-09-2021 02:45 PM
Hi Graham,
Rasika
03-10-2021 09:53 AM
Rasika,
That works fine, thought it would just be something simple.
Cheers
