AIR-CAP3702E-A-K9and WLC5508
Robin Swan
I have a 5508 WLC with the 7.6.120.0 Software Version.  I connect some new, out-of-the-box AIR-CAP3702E-A-K9 AP's and they show:
CleanAir Admin Status = Enable
CleanAir Oper Status = DOWN
When I go to the "Wireless" Tab, then to "Radios" on the menu and select "Configure" on the AP, CleanAir Admin Status is on "Enable."
Does this mean that the AP is doing the CleanAir?
Thank you in advance.
Stephen Rodriguez
No the AP is not doing Clean Air if the Oper Status is down.
Go to the main 802.11b/g/n and a/n/ac tab and make sure that Clean Air is enabled globally:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70cleanair.html#wp1162863
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
It worked.  Thank you very much!
