AIR-CAP3702E-E-K9 red blink
TKA000328
The access point blink red, in console is possible to see "ap:" command
ap: dir flash:
Directory of flash:/
2 -rwx 64 <date> sensord_CSPRNG0
3 -rwx 85 <date> mesh_port_cfg.txt
5 -rwx 570 <date> env_vars
4 -rwx 368 <date> capwap-saved-config-bak
6 drwx 0 <date> configs
11 -rwx 424767 <date> crashinfo_20160916-110408-UTC
8 -rwx 64 <date> sensord_CSPRNG1
9 -rwx 66662 <date> event.log
10 -rwx 368 <date> capwap-saved-config
40661504 bytes available (497152 bytes used)
ap:
2 Accepted Solutions
patoberli
This looks like it's missing a boot image, but I'm not 100% sure.
This recovery guide should work though, just make sure to use an image for the 3700 series.
https://community.cisco.com/t5/wireless-mobility-documents/access-point-rommon-recovery-ap-prompt-recovery-example/ta-p/3119495
First the basics, do you have a WLC?
If not, then you need to switch to the autonomous image.
Download: https://software.cisco.com/download/home/285029865/type/284180979/release/15.3.3-JPM
If you do have a WLC, but not having DNS or DHCP for capwap discovery configured, then you find here the command for static IP and also the command for static WLC assignement:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/wave2-ap/command-reference/8-8/b-cisco-wave2-ap-cr-88/capwap_commands.html#wp2266101261
patoberli
OK, now I get this message :
*Sep 16 11:08:00.691: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.$ssigned or assigned IP is wrong. Renewing DHCP IP.
How can I set manually the IP address using cable console ?
We have WLC but not DHCP at the moment, manual IP set, now is managed by WLC.
Thank you
