AIR-CAP3702I-D-K9 speed and range settings
Hello Team,
I have a 3602I-D-K9 AP which gives me a throughput/speed about 50-60 Mbps (differing) at 5GHz ,
However when I configured AIR-CAP3702I-D-K9 the results are not quite pleasing ,it gives me throughput/speed about 30-50 Mbps(differing) at 5GHZ which is lesser then AIR-CAP3602I-D-K9...
there are 80 Users and i have placed 2 units of  3702I-D-K9 in two different positions far from each other and there is no much Interference such as walls ...except glass panes on the corners which should not be a problem as the users are not past the Glass panes and  signal needs not to cross the glass panes.
I had no issues with 3602 but when i replaced the same environment with 3702 AP'S the problems started...
i have created SSID's with WPA2 encryption and the rest settings in each dot11Radio Interfaces are not changed and are default settings, Similar way i had even configured the 3602 AP's the ISP is providing me 500Mbps data rate..
So now could some one please  help me here why is the 3702I-D-k9 access point giving  an almost equal throughput/speed or much lesser throughput/speed when compared with 3602I-D-K9 ..do I need to set any speed or range parameters on each RADIO interfaces  ?? if so can someone share me how can i do it ??? the speed and range parameters are quite confusing ....
Rasika Nayanajith
What channel width you using under 5GHz (RRM -> DCA), 20MHz,40MHz ?
Also what data rates you enabled on each band ?
If there is a way to test one of those APs with your best client (no other clients in that cell), it would be the best case scenario. Use iperf if possible.
https://mrncciew.com/2014/01/10/802-11ac-with-cisco-3700-ap/
https://mrncciew.com/2014/08/08/how-fast-is-your-network-iperf/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
