03-03-2020 06:21 AM - edited 07-05-2021 11:48 AM
the below is from a console connection. Reboots constantly.
Answers on a postcard, please?
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 82 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 37996544
flashfs[0]: Bytes available: 3162112
flashfs[0]: flashfs fsck took 23 seconds.
Base Ethernet MAC address: b8:38:61:57:60:fc
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JD11/ap3g2-k9w8-mx.153-3.JD11"...###########
File "flash:/ap3g2-k9w8-mx.153-3.JD11/ap3g2-k9w8-mx.153-3.JD11" uncompressed and
installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Montserrat Board
40MB format
flashfs[0]: flashfs fsck took 25 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 1 seconds.
Boot CMD: 'boot flash:/ap3g2-k9w8-mx.153-3.JD11/ap3g2-k9w8-xx.153-3.JD11;flash:
/ap3g2-k9w8-mx.153-3.JD11/ap3g2-k9w8-xx.153-3.JD11'
Loading "flash:/ap3g2-k9w8-mx.153-3.JD11/ap3g2-k9w8-xx.153-3.JD11"...###########
File "flash:/ap3g2-k9w8-mx.153-3.JD11/ap3g2-k9w8-xx.153-3.JD11" uncompressed and
installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JD11, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Fri 27-Oct-17 22:58 by prod_rel_team
Montserrat Board
40MB format
Initializing flashfs...
flashfs[2]: 82 files, 9 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 37996544
flashfs[2]: Bytes available: 2904064
flashfs[2]: flashfs fsck took 21 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/Q2.bin
Radio1 present 8864 8000 0 80000000 80100000 4
%Software-forced reload
Buffered messages:
Queued messages:
*Mar 1 00:00:37.527: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console d
ebugging output.
*Mar 1 00:00:26.051: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed (15)
*Mar 1 00:00:26.511: Registering HW DTLS
*Mar 1 00:00:29.671: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar 1 00:00:32.163: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:32.279: loading Power Tables from ram:/Q2.bin. Class = E
*Mar 1 00:00:32.279: record size of 3ss: 1168 read_ptr: 5006C7E
*Mar 1 00:00:37.451: %SOAP_FIPS-2-SELF_TEST_RAD_FAILURE: RADIO crypto FIPS self
test failed at AES 128-bit CCM encrypt on interface Dot11Radio 1 -Process= "Ini
t", ipl= 0, pid= 3
test failed at AES 128-bit CCM decrypt on interface Dot11Radio 1 -Process= "Ini
t", ipl= 0, pid= 3
00:00:38 UTC Mon Mar 1 1993: Unexpected exception to CPU: vector 700, PC = 0x13
468C0 , LR = 0x13468C0
-Traceback= 0x13468C0z 0x13468C0z 0x1810608z 0x12CDC74z 0x12CDE54z 0x12CDFC0z 0x
10C41ECz 0x10C4464z 0x1347D30z 0x132EABCz
CPU Register Context:
MSR = 0x00029200 CR = 0x24244022 CTR = 0x011B6480 XER = 0x00000000
R0 = 0x013468C0 R1 = 0x05007888 R2 = 0x00010001 R3 = 0x05009670
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x011B6EEC R7 = 0x00000000
R8 = 0x00000002 R9 = 0x00000000 R10 = 0x03CF0000 R11 = 0x03CF0000
R12 = 0x24244024 R13 = 0x88562890 R14 = 0x00000001 R15 = 0x03D45C24
R16 = 0x03D45C7E R17 = 0x00000000 R18 = 0x0000004C R19 = 0x00000001
R20 = 0x000000FF R21 = 0x00000004 R22 = 0x09B17F8C R23 = 0x09B57F8C
R24 = 0x018837F8 R25 = 0x09A66C0C R26 = 0x00000001 R27 = 0x09A68978
R28 = 0x09B46C80 R29 = 0x03809970 R30 = 0x0380309C R31 = 0x00000000
TEXT_START : 0x01003000
DATA_START : 0x03000000
MCSRR0: 0x00000000, MCSRR1: 0x00000000 MCSR: 0x00000000 MCAR: 0x00000000
Total PCI 0 MC Error = 0; PCI LD count=0
Total PCI 1 MC Error = 0; PCI LD count=0
Total PCI 2 MC Error = 0; PCI LD count=0
Writing crashinfo to flash:crashinfo_19930301-000038-UTC
Nested exception_rom_monitor call (2 times)
Unexpected exception to CPUvector 700, PC = 13468C0
Exception (700)! Program
SRR0 = 0x01465B18 SRR1 = 0x00029200 DEAR = 0x00000000
Vector = 0x00000700 PC = 0x013468C0 MSR = 0x00029200 CR = 0x24244022
LR = 0x013468C0 CTR = 0x011B6480 XER = 0x00000000
Stack trace:
PC = 0x013468C0, SP = 0x05007888
Frame 00: SP = 0x050078A0 PC = 0x013468C0
Frame 01: SP = 0x050078B8 PC = 0x017F9BC0
Frame 02: SP = 0x05007980 PC = 0x01810608
Frame 03: SP = 0x05007998 PC = 0x012CDC74
Frame 04: SP = 0x050079B8 PC = 0x012CDE54
Frame 05: SP = 0x050079D8 PC = 0x012CDFC0
Frame 06: SP = 0x05007A18 PC = 0x010C41EC
Frame 07: SP = 0x05007B28 PC = 0x010C4464
Frame 08: SP = 0x05007B30 PC = 0x01347D30
Frame 09: SP = 0x00000000 PC = 0x0132EABC
SOFTWARE (fc1)
ap uptime is 42 seconds
cisco AIR-CAP3702I-E-K9 (PowerPC) processor (revision A0) with 376814K/134656K b
ytes of memory.
Processor board ID FCZ1804P10X
PowerPC CPU at 800Mhz, revision number 0x2151
<<system reboots>>
flash is writable
flashfs[0]: Bytes used: 37995520
flashfs[0]: Bytes available: 3163136
executing...
Montserrat Board
40MB format
03-03-2020 06:52 AM
- Have a factory defaults reset of the AP , if that does not help consider the following :
ref : https://www.cisco.com/c/en/us/td/docs/wireless/access_point/atnms-ap-82/configuration/guide/cg-82-book/cg-appC-errormsg.html
Error Message SOAP_FIPS-2-SELF_TEST_RAD_FAILURE: “RADIO crypto FIPS self test failed at %s on interface %s %d.”
Explanation SOAP FIPS self test on radio crypto routine failed.
Recommended Action Check radio image.
The mentioned action apparently relates to 'internal' stuff and or it may be advisable to RMA the AP.
M.
03-03-2020 08:39 AM
