AIR-CAP3702I, showing red indication
We have "AIR-CAP3702I-E-K9" some access point giving red indicator led. When the same AP is connected to switch directly it gives green indication.
Customer update us cabling is tested and passed, but the AP connected to the wall shows red indication, please suggest what could be the problem.
Top Panel LED Signals
Message
type
Ethernet
LED
Status
LED
Radio
LED
Meaning
Boot loader status
Green
Green
DRAM memory test.
Amber
Red
Board initialization test
Blinking green
Blinking green
Flash memory test.
Amber
Green
Ethernet initialization test.
Green
Green
Green
Starting Cisco IOS.
Association status
Green
At least one wireless client device is associated with the unit.
Blinking green
No client devices are associated; check the unit's SSID and WEP settings.
Operating status
Green
Blinking green
Transmitting/receiving radio packets.
Green
Ethernet link is operational.
Blinking green
Transmitting/receiving Ethernet packets.
Boot Loader Errors
Red
Red
DRAM memory test failure.
Red
Red
File system failure.
Red
Red
Ethernet failure during image recovery.
Amber
Green
Amber
Boot environment error.
Red
Green
Red
No Cisco IOS image file.
Amber
Amber
Amber
Boot failure.
Operation Errors
Green
Blinking amber
Maximum retries or buffer full occurred on the radio.
Blinking amber
Transmit/receive Ethernet errors.
Blinking amber
General warning.
Configuration Reset
Amber
Resetting the configuration options to factory defaults.
Failure
Red
Red
Red
Firmware failure; try disconnecting and reconnecting unit power.
Firmware Upgrade
Red
Loading new firmware image.
Controller status
Alternating green, red , and amber1
Connecting to the controller.
Note If the access point remains in this mode for more than five minutes, the access point is unable to find the controller. Ensure a DHCP server is available or that the access point has been primed with the controller information.
Check tis guide for mor einformaiton
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/3700/quick/guide/ap3700getstart.html
mohanak
 try disconnecting and reconnecting unit power:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/3700/quick/guide/ap3700getstart.html#85902
