AIR-CAP3702I
vezeh
Frequent Visitor
Frequent Visitor
Hi Everyone,
I need a little bit of verification based on facts;
I am aware that Cisco APs designated for my region (Nigeria) are the AIR-CAP3702I-E-K9 model APs. I want to find out if the model AIR-CAP3702I-A-K9 can be used here also.
Cisco does not specify that it can be used, but in a case where it is being used, what are the limitations to be expected?
6 Replies 6
Sandeep Choudhary
HI,
It should not be used.
The reason behind this is because the wifi Regulatory Domain for Nigeria/Europe(-E) and US (-A)are totally different.  In order to comply, Cisco's WLC will only allow COMMON factors to be enabled.
Dont forget to rate helpful posts
ngkin2010
Level 10
Level 10
Is it configured as lightweight AP or standalone AP?
vezeh
Frequent Visitor
Frequent Visitor
It is a lightweight AP
HI,
Dont forget: Running wrong country code is illegal as well.
Best case is, return the AP (with the wrong Regulatory Domain) to the vendor and ask them to exchange for the one with the correct Regulatory Domain.
or
Run the AP in autonomous mode.
@Sandeep Choudhary wrote:
HI,
or
Ok.....
 Thanks a lot
Leo Laohoo
Yes and no.
Technically, the answer is no (reason below).
However, it can be done ... but with consequences.
Because of the conflicting Regulatory Domain, the controller will only enable radios where the rules are both the same.  If there are rules which are conflicting then the radio(s) or channel(s) will be disabled.
It is for this reason why we dissuade people from putting APs with different Regulatory Domain into a single controller.
