Air-CB21AG-A-K9 Aironet wireless 802.11 a/b/g problem.
KhangVie1
My cisco aironet 802.11 a/b/g got a problem. when I put the
card into the laptop, it recognize a new hardware; until installing
driver...then it got freezing. I try it so many times it had the same
problem. (I mean the card can't installing the driver). It stopped at c://windows/system32/driver while installing file cisco21.sys .After that everytime i put in the card . it got freezing .I used Window XP
SP2. Please help me out! thank a lot.
10 Replies 10
KhangVie1
Aironet Desktop Utility
Troubleshooter report...
Report date: Friday, December 17, 2004
Name: Driver installation test
Description: This test is to check the radio driver installation.
The radio's registry keys are OK.
Nic name. . . . . . . . . : Cisco Aironet 802.11a/b/g Wireless Adapter
Driver name . . . . . . . : CSCO21
Driver path . . . . . . . : C:\WINDOWS\system32\DRIVERS\csco21.sys
Driver version. . . . . . :
Active Profile Name . . : Not Found
Test Failure: Driver has not been installed correctly.
Solution: Try reinstalling the software.
If that does not work, try replacing the radio.
Test not completed.
I cant installing driver . My old card Aironet 350 still working good.
Note :if i put csco21.sys in systems32/driver my laptop got freezing right way.
Do you have other wireless NIC installed (other than the 350)? Can you install driver alone?
I really don't know what happend . it's working really good before i format and reinstall windows . I have 2 cards . the old card 350 still working good. The new card A/B/G can't install driver either way it still freezing at file ..csco21.sys. I have to turn off the power of comp. then turn on again. If I put the new wireless card on it freeze right away.
If you install the Aironet Desktop Utility (ADU), ADU may compete Windows resources with other services/application. I suggest you to install the driver only. If that's still fail, do you install the same CB21AG card on other laptop?
i tried both ADU and Driver Only it is still fail. But i didn't try with other laptop . I will try with other laptop then i will let you know . thanks
Yes, It works for other laptop . But not my laptop . :)
You need to open a TAC Service Request. We need to get Development Engineer involved.
i already fix it . My laptop is Compaq Evo N1020V so i have to install System Enhancements WindowsXP . Before put in . other way it will be hung.
i am facing the same problem....
what xp system enhancements you installed
