Problem with Web Authentication.
slandeira
Level 3
Level 3
In our case I have a Radius Server for Web Authentication.
I have a SSID guest for Web access, of such form that any user of any group can authenticate itself like guest.
In the AD to the guest group I have not associated nothing. The error that gives when connecting a user of grupoX to the SSID guest is ?The user tried to use an authentication method that is not allowed in the director of corresponding remote access?
Premdeep Banga
Level 10
Level 10
Is IAS acting as the radius server?
If yes, try enabling PAP as the authentication protocol , which is not enabled by default. You can also get more information, as why the user is not able to connect, by checking the radius server logs.
Prem
