AIR-CT2504-50-K9 with out DHCP Static config
We have AIR-CT2504-50-K9 and AIR-CAP1602I-TK910 30 devices we want config trough controller to AP with out DHCP
5 Replies 5
Hi Rao,
What do you mean by "we want config trough controller to AP with out DHCP" ? Does this mean you want AP to discover WLC without using DHCP?
You can use DNS instead.
Anyway please clarify your question to provide you a good response
Rasika
We have AIR-CT2504-50-K9 and AIR-CAP1602I-TK910 30 devices we dont have DHCP Server
with out DHCP how to configure static ip on AP and end users.
You can configure cisco IOS device (switch or router) as your DHCP server, you do not required seperate DHCP server to do this.
Rasika
you can use any opens source OS as DHCP server like centOS etc or as mentioned use router or switch for the same.
Saravanan Lakshmanan
#Yes, you can use internal dhcp server on WLC-2500 to lease IPs to the connected APs using L2/Broadcast, once AP gets an ip then you can make those IPs as static on those APs via check box from AP's general tab after it joins the WLC.
#Remeber, WLC dhcp doesn't support option 43, if the AP and WLC management are L3, be sure to use ip-helper at L3 for wlc discovery. Also, don't think AP may receive ip from WLC dhcp server when it is L3 and dhcp proxy is used instead of broadcast.
