AIR-CT3504-K9 Corrupted...(?)
Axel.Nieto
Hello everyone.
I have the next problem, Attach an evidence log:
Octeon cust_kukrip2(ram)# fatload usb 0 0x20000000 AIR-CT3504-K9-8-5-131-0.aes
** Bad device usb 0 **
Octeon cust_kukrip2(ram)# start     usb start
(Re)start USB...
USB0: Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
reading AIR-CT3504-K9-8-5-131-0.aes
307631338 bytes read in 11179 ms (26.2 MiB/s)
Octeon cust_kukrip2(ram)# sf write $(loadaddr) $ 0 $(filesix ze)
No SPI flash selected. Please run `sf probe'
Octeon cust_kukrip2(ram)# sf probe
SF: Detected S25FL064A with page size 256 Bytes, erase size 64 KiB, total 8 MiB
Octeon cust_kukrip2(ram)# sf write $(loadaddr) 0 $(filesize)
ERROR: attempting write past flash size (0x800000)
Octeon cust_kukrip2(ram)# sf erase 0 0x800000
SF: 8388608 bytes @ 0x0 Erased: OK
Octeon cust_kukrip2(ram)# tftpboot 0x20000000 AS_3500_OFD.8.5.1.164.man
Using octmgmt0 device
TFTP from server 10.1.1.1; our IP address is 10.1.1.111
Filename 'AS_3500_OFD.8.5.1.164.man'.
Load address: 0x20000000
Loading: *##################################################
12.2 MiB/s
done
Bytes transferred = 20217201 (1347d71 hex)
Octeon cust_kukrip2(ram)# reset
Cisco bootloader . . Could not start next bootloader
I tried to boot an image in my unit, but when I made a reset...that happens...
I think I´ve been corrupted the device...
Does anyone of you knows if this issue have a solution?
Thanks and regards
Axel.Nieto
Btw...I know that AS_3500_OFD.8.5.1.164.man it´s a correct image because I´ve been booted before by fatload USB...but I tried to solve to boot from TFTP.
