AIR-CT3504-K9 log提示 CPLD failure.
jokerxie
Hi all
I found the alarm in the log. How do I solve the fault
*envFanMonitorStatus: Jun 28 16:25:01.710: %ENVMON-3-CPLDFAIL: kukri_fan.c:121 CPLD failure.
RoadRunner4k
Which version are you using on the WLC? and have you check the status of FANs ? from the description it could look like a fan issue.
The WLC using version is 8.10.171.0
Fan status is ok
I think maybe we need to restart WCL or update to the recommended version to fix it
     >...I think maybe we need to restart WCL or update to the recommended version to fix it
   Good plan the older aireos based controllers should nowadays always use the last release available for the
  particular model : https://software.cisco.com/download/home/286312601/type/280926587/release/8.10.196.0
 M.
