AIR-CT5508-12-K9
please,
  I need to know if WLC AIR-CT5508-12-K9 supports the folowing model off Access point:  AIR-LAP1131-A-K9, AIR-LAP1242G-A-K9, AIR-BR1310G-A-K9, AIRCAP-16021-A-K9
luckymike33
Hi there,
You should check this document out
- http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn7_0_116_0.html#wp610751
It all depends in which version of software your WLC is running.
ok, thanks for your answer, but I have some doubts about the Table 2 of the document.
for example, the access point AIR-LAP1131 supports only realease 3.1.59.24, but the AIR-LAP1242AG supports realease 3.1.59.24 and ---
 which means -----  in the table off document?
Basically, the versions you are quoting are the START of the supported version and if you look at the next column to the right, you'll notice that there is no "end" software version.
This means that, for example 1131 support starts from from WLC firmware 3.1.59.24 and up to the most recent firmware.
Does this make any sense?
