AIR-CT7510-K9 physical connectivity to 1gig rj45 switch port
Sandeep Gupta
Hello
We have AIR-CT7510-K9 supporting 500 AP. As per datasheet it has 2X10Gig port however we have only 1Gig switch port on switch.
Please advise solution for physical connectivity for WLC & switch with 1Gig access?
Not possible.  Only SFP-10G-SR or SFP-10G-LR allowed.  There is no such thing as a Cisco SFP+ copper module.
Leo Laohoo
I believe 7510 only supports SFP+.
Hi Leo
WLC is 10gig sfp capable however I need understanding on physical connectivity ..is this possible to have gig rj45 other side?
ali aqrabawi
Level 3
Level 3
as per link below, the switchport should be 10 gig and same SFP+ :
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/Flex_7500_DG.html
• LAG support for 2x10G interfaces allows active-active link operation with fast failover link redundancy. An additional active 10G link with LAG does not change the controller wireless throughput.
  • 2x10G interfaces.
  • 2x10G interfaces support optic cable with SFP product # SFP-10G-SR and SFP-10G-LR.
  • Switch side SFP or X2 product should be of the same type SR or LR.
