09-10-2013 10:00 PM - edited 07-04-2021 12:48 AM
Hello Everyone,
I am facing some problem in AIR-LAP1141N-A-K9.in this AP if 21 user connected then no one can't browse even we can't get ping from the Gateway. But if the user is below 20 then everyone can browse and we also get the reachibility to the Gateway. How many user can use through this AP ??
It's an urgent issue.please post your suggestion as soon as possible.
Shihan
09-10-2013 10:26 PM
Check under WLAN advanced settings "Maximum Allowed Clients Per AP Radio" is configured for certain value ?
Rasika
09-10-2013 11:15 PM
maximum allowed clients is configured 0 and Value zero implies there is no restriction on maximum clients allowed but still remains the same problem
09-11-2013 01:00 AM
This doesn't make any sense. Can this user get a valid IP address when there are 21 or more users?
09-11-2013 01:36 AM
yes,the 21st user get a valid ip....if a AP connected less than 20 user they can browse or download.
09-11-2013 03:16 PM
You know what this smells like? I think you have a wired network congestion.
On the AP, post the "sh interface G0". I would also like to see the following commands from the switch:
1. sh interface
2. sh controll e
09-11-2013 12:56 AM
There are no restrictions itself on the AP. how many other APs do you have and also how many wired users? You seeing this issue on just one AP or all APs together?
09-11-2013 01:32 AM
Hi Scoot,
we have 25 Ap's with a WLC.....We are facing this problem in all AP's indivitualy not all together...and we are using 13 local lan in wired.
