AIR-LAP1242AG-A-K9 Antennas
MARY MARINILLI
Is there an FCC regulation that restricts 802.11g 15db antennas for use on this model AP (AIR-LAP1242AG-A-K9) in the US?
jeff.kish
Level 7
Level 7
The FFC restricts using any antenna that has higher gain than the largest produced by the AP manufacturer:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008022b11b.html
This also depends on the type of antenna. So take a look at this list of Cisco-made antennas. If you can't find an antenna of the same type and greater-than or equal to your antenna's dB, it is not allowed by the FCC.
Jeff
Excellent, thank you!!
