AIR-LAP1252AG-A-K9 Power Loss
preilly78
WLC 4404 5.2.157
WCS
I have been watching the event logs and I have an AP or two that seem to be restarting alot. When they do the log on the WLC states that the reason for last restart was "power loss". I swapped the AP with another power injector and the problem didnt follow. Would this be a hardware issue at this point? It happens every 3-5 hours....
Attached log (hopefully cut and pasted):
16 Mon Feb 9 07:49:25 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio
MAC:00:22:90:a1:a9:c0 Cause=Admin Configured
17 Mon Feb 9 07:49:25 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio
18 Mon Feb 9 07:49:25 2009 AP's Interface:1(802.11a) Operation State Up: Base Radio
19 Mon Feb 9 07:49:25 2009 AP's Interface:1(802.11a) Operation State Down: Base Radio
20 Mon Feb 9 07:49:25 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio
21 Mon Feb 9 07:49:25 2009 AP's Interface:1(802.11a) Operation State Up: Base Radio
22 Mon Feb 9 07:49:25 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio
23 Mon Feb 9 07:49:25 2009 AP 'HS_AP_407', MAC: 00:22:90:a1:a9:c0 disassociated previously
due to AP Reset. Last reboot reason: power loss
24 Mon Feb 9 07:49:25 2009 WIPS Alert: Reason "NoProfile" detected on AP MAC:
00:22:90:a1:a9:c0, AP Name: HS_AP_407
Leo Laohoo
"I swapped the AP with another power injector and the problem didnt follow."
Sounds like the power injector could be faulty.
Well I thought that but I have random APs that do it now to. I can expect about 4-5 Access points to drop during the day. If they are close enough to each other it will cause an outage. I submitted a TAC request for help see if I can get it resolved.
Hi Guys,
Did anyone get the solution to this problem?
I'm with the same problem. I've changed the power from power injector to switch POE and check the comsuption on switch and the problem persist.
9 Sat Mar 14 02:17:06 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:1d:a1:75:92:50 Cause=Admin Configured
10 Sat Mar 14 02:17:06 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1d:a1:75:92:50 Cause=Admin Configured
I have one WLC working fine on HQ site and I have this problem with remote APs working with H-REAP.
Hi Gilbert,
If your AP is on a power injector, go to All APs > Details for AP -> Advanced Tab -> Power Over Ethernet Settings and enable Power Injector State and click Apply.
