AIR-LAP521G-E-K9
kvacha1337
Good afternoon!
I'm having issues with  AIR-LAP-521G-K9 access pont. I was unable to find any documentation guide for this AP. The issue is that CLI doesn't work and I'm assuming it's not supported so it should be configured using CNA or something similar, but I'm unable to connect anyways.
Have you guys ever worked with this AP and have any experience configuring it, all sort of help would be much appreciated.
Thanks in advance,
Regards Alex
Scott Fella
I have not used that AP, but here are some links I have found.
http://www.manualowl.com/m/Cisco/AIR-AP521G-A-K9/Manual/290844
-Scott
