03-05-2013 02:04 AM - edited 07-03-2021 11:40 PM
Hello
I have a Controller 5508, CAP 3501E
I have a problem, all client who connect in 802.11n connect only in Bn and not in Gn.
When I diseable the n, the same client connect in 802.11g.
Could you help me that the client can connect in Gn
Thank you
christophe
03-05-2013 02:11 AM
Go to Wireless > 802.11 b/g > Network.
Disable all data rates 12 Mbps and below. Make 18 as Supported and 24 as Mandatory.
03-05-2013 02:17 AM
hello
thank for the answer
I test this protocole.
Thx
03-05-2013 02:50 AM
Hello
I test this
but not good result
the controller version is
03-05-2013 04:06 AM
So the requirements for 802.11n is:
Use open or WPA2/AES
Enable WMM
Optional is 40mgz channel width (5ghz only)
