AIR-LMC352
lemicka
Is the lmc352 wireless LAN adapter designed to be removed from its caddy? It appears to be removable but I want to ask you experts before I apply force and destroy the adapter. I want to use the adapter in my IBM 600e laptop.
Thanks!!!!
b.withrow
Yes, it is removeable, unless the vendor of the device has somehow attached it permanently.
