AIR-MNT-ART1 angle with C9124AXD
arjen E
The AIR-MNT-ART1 can be used to mount the AP ot the ceiling in a horizontal plane:
(https://www.cisco.com/c/en/us/td/docs/wireless/access_point/9124ax/install-guide/b-hig-9124ax/installation-overview.html#ap_horizontal_wall_mount)
In my case, i want to mount the AIR-MNT-ART1 to the ceiling and change the angle (to about 30-45degrees) and attach the C9124AXD (with build in directional antenna).
Is there enough space between the C9124AXD and the ceiling with this mount unit to create this angle ?
Arjen.
6 Replies 6
Leo Laohoo
NOTE:  AIR-MNT-ART1 & AIR-ACC1530-PMK2 are the same model.  Different SKU for sales reasons.
AIR-MNT-ART1 can only angle the antenna in a single direction:  Either horizontal or vertical.
Depending on the application, we have used AIR-MNT-ART1 against the wall and we have not encountered any problem.
arjen E
@Leo Laohoo Thanks for your quick response !
The AIR-MNT-ART1 can only be used in 2 directions. :-(.  Is there a outdoor bracket available for the C9124AXD with other possible angles ?  Is the best solution a C9124AXE with external directional antenna?...
No, AIR-MNT-ART1 can only support one direction:  Either vertical or horizontal.
We are using AccelTex's articulated arm because this model can support two directions.
https://www.acceltex.com/shop/cisco-air-ant2566d4m-r-patch-antenna-articulating-mount/
Dustin Anderson
The AIR-MNT-ART1 says it can adjust on the vertical plane, so I would guess it should handle the 30-45 degrees, but I can't fins anything specific so if anyone has one to verify. I have also used Acceltex and they have been good for what I have done
arjen E
The AIR-MNT-AIR1 does it fit on the C9124AXI , C9124AXD and the C9124AXE ?  It is not very clearly described in the documentation.
It does.
