Air-P121AG-A-K9 WPA/TKIP
rchapman
I have installed the above adapter into a desktop unit, I am wanting to use windows instead of the ADU option. but for some reason I do not have the option to use WPA with TKIP for our network, setting it up in the preferred networks list. The antenna sees the AP but will not connect to it either. we have tkip keys that we use and have installed on the PC in the trusted root dir. but winXP will not recognize the WPA protocol.
scottmac
Level 10
Level 10
XP Service Pack 2 and some patches from Microsoft.com should take care of it.
Try a search on microsoft.com using keywords like "WPA" and / or wireless
Good Luck
Scott
scottmac
Level 10
Level 10
Good Luck
Scott
Thanks for the help, I did have all updates for WinXP sp2 but I did try the kb917021 on one test box, it made no difference.... But I did notice that the driver package that came with the pci wireless unit was using ver 2.1 I had downloaded ver 3.0 a couple days earlier for a laptop issue and found that the cisco for the laptop and the pci were the same driver, so I put in the newer driver and it worked first time out. As a Tech I should have known better than to use the factory install disk....;) All is good.
