ā11-27-2023 08:39 PM
Where to order this AIR-PWRADPT-RGD2?
This item is not available in CCW.
Please tell how to order this or the replacement for this.
ā11-27-2023 08:44 PM
AIR-PWRADPT-RGD1= is only available for order. Is this adapter is compatible with C9124AXI-ROW
ā12-01-2023 12:18 AM
@Rich R this?
ā12-01-2023 03:12 AM - edited ā12-01-2023 03:14 AM
No AIR-PWRADPT-RGD1 has a different connector so if you bought that you would have to cut off the connector then solder and seal the correct connector for 9124 which would possibly compromise the outdoor rating. Rather buy the correct part. AIR-PWRADPT-RGD2= shows as orderable for me in CCW on EMEA availability price list so maybe it's not sold in your local theatre - maybe because of regulatory compliance?
You could try third party resellers which might stock it locally or order from elsewhere.
ā11-29-2023 03:50 PM
Input power requirements |
ā 802.3af Power over Ethernet (PoE), 802.3at PoE+, 802.3bt PoE++, Cisco Universal PoE (Cisco UPOE)
ā Cisco power injector, AIR-PWRINJ-60RGD1= and AIR-PWRINJ-60RGD2=
ā Cisco power injector, AIR-PWRINJ6= (Note: This injector supports 802.3at)
ā DC power source: Auxiliary DC input, 24V to 56V
