02-19-2011 11:54 AM - edited 07-03-2021 07:50 PM
What are the Product ID’s (PIDS) and/or Part Numbers of Cisco Wireless Access Points that are compatibility with the AIR-WLC2006-K9? Can the AIR-AP1252G-A-K9 be converted to Lightweight and be used with the AIR-WLC2006-K9? If so, what is the minimal version of code required on the AIR-WLC2006-K9?
02-19-2011 02:05 PM
Yes, 1252 can be converted to LWAPP. You can download the utility and code under the download, folder for the access point 1252.
02-20-2011 01:35 AM
The WLC 200X can support only 4.2.X code. This code should support the 1250 and older AP. It won't support newer APs like the 1040, 1140, 3500, 1260.
Nice one George (+5).
