AIR-WLC526-K9 usb function?
Dennis Wieringa
Level 2
Level 2
i have an AIR-WLC526-K9 and notiched that is holds 2 usb ports.
but my experience with an PIX515E and PIX506E, also having 1 usb port, is that these ports are just for show. because there is no functionality/use for them on the software side.
or none that i can find.
but knowing the WLC is newer than the PIX, im curious if these does work, or holding a kind of function.
Saurav Lodh
Level 11
Level 11
Yes the two USB are the console for future expansion.
Saurav Lodh
Level 11
Level 11
Well, according to the site below, its allready EOL, so i take it that there isnt any 'future expansion'.
just like the PIX'es i mentioned.
http://www.cisco.com/c/en/us/products/collateral/wireless/526-wireless-express-mobility-controller/end_of_life_c51-568040.html
its actually a shame, giving appliances ports for future expansion, and then EOL'ing it.
thnx anyways
