I want to bridge two location point to point with distance 2km to 3km , one location has access points AIR-1242G and ANT-1949 antenna, and the other location has AIR-1252G-K9 and ANT-1949 antenna.
Can this be done regarding my above equipments,??
As my access points is indoor and i want to use it as outdoor with ANT-1949, is it possible to reach the above distance????
Is my access points compatible with the antenna ANT-1949????
if yes, is there a configuration guide to configure the above scenario,!!!
plz advice..
