Showing results forĀ
Search instead forĀ
Did you mean:Ā
AIR1242AG how many antennas??
ANUJ BUTAIL
My customer wants to by AIR1242AG with 2.4 GHZ antennaes which are not ceiling mounted
How many 2.4 GHz antennas I can have on the  AIR1242AG??
Can I have a recommendation which antenna I should use which is not ceiling mounted??
Let me know incase you have further questions
Scott Fella
You only can have up to two (2) 2.4ghz on the 2.4ghz and up to two (2) on the 5ghz.  Here is a reference guide to show you the different antennas that are available, I'm guessing you will be using the dipole then if its an office environment.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
-Scott
