air2125
jcastanos
Level 2
Level 2
HI,
I have a problem.  my air-wlc2125 don't boot.. . a this moment, when  I power on  wlc-2125  online  led power is green and status red (ambar??)
that's not posible access with a  console cable..  ( not message)
Any suggestions???!!.
Sandeep Choudhary
Its broken.You need to change it.
If you have bit knowledge of memory card then try to insert new one on WLC but i dont recommand to do it own, you can take help from profession technical person.
or If you have a valid support contract then need to RMA the device and ask for new one.
Dont forget to rate helpful posts
hi,
thanks.
That is a very old device... you might be better off fining a WLC 2504 online if you want something that isn't too expensive.
Scott
-Scott
