AireOS 8.2.151.0 and ISE 1.2 compatibility
marce1000
 - Will AireOS 8.2.151.0 (still) work with ISE 1.2 (the testbed in the release notes mention ISE 1.4 , yet for the time being I need to use 1.2) ?
M.
Sandeep Choudhary
No its not compatible with Cisco ISE 1.2.
Here is the compatibility matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
Sandeep Choudhary
