Sh tech and sh tech wireless are required
jphvpichi
hi,
I have a 5760 with 3.6.4, when i upload the wlc config on the wlc analyzer i got the msg:
Controller wlc_name information is incomplete. Sh tech and sh tech wireless are required
This is a bug?.
i have uploaded also the sh tech and sh tech wireless on different files or in the same.. but the msg still appears after the upload.. this is normal..
Do i need to upload only one file for config, sh tech and sh tech wireless...?.
regards,
Juan Pablo
Javier Contreras
Hola Juan Pablo
for IOS-XE, you should load in a single file the output for sh tech and sh tech wireless
if that is not working, please send me the file zipped, and I will test it here
For 16.x, it is just sh tech wireless
regards
Javier Contreras
Hola Juan Pablo
regards
Hi Javier,
I got it, first i upload the wlc config and then only the sh tech wireless.
thanks for your help
regards,
Juan Pablo
Hi there
I have the same problem trying to analyze the config from a 5760 running on 03.06.03E. I am using WLCCA version 4.3(7) and I have tried uploading every possible combination of the 'show running-config', 'show tech' and 'show tech-wireless' files.
Thanks for any help on this.
Christian
All of a sudden it works...
Thats how I did it just in case someone else is having the same issue sometime.
- create a txt file
- first add the output of WLC#show tech on top
- then add the output of WLC#show tech wireless beneath
- save the txt file
- open the file with WLCCA
