aironet 1200 /1240 problem
theodionys
I have the following problem with my APs.
I use snmpset to change an object's value. I set
the new value succesfully, but when i try to get the new value the snmp agent returns the old value.
setting....
root@teo:/home/teo# snmpset -v 2c -c demopublic 192.168.1.11 CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1 u 2
the agent reports the new value....
CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1 = Gauge32: 2
here is the problem....
root@teo:/home/teo# snmpget -v 2c -c demopublic 192.168.1.11 CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1
CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1 = Gauge32: 255 <======== the old value ======
I have tried snmpset with other objects and it works fine.
gmarogi
Level 5
Level 5
From where did you try to set the snmp values?. Is it from WLSE? or if it is a light weight AP, did you try this with the WCS?
