Aironet 1240AG conversion problem
idrisakinyemi
Community Member
i am trying convert my AP from ightweight mode to Autonomo
us mode, i av already followed all the required steps but i am getting the following error messages
on AP console: ERROR: Failed to extract from archive file tftp://255.255.255.255/c1240-k9w7-tar.default
on the TFTP server:  Connection received from 10.0.0.1 on port 1024 [17/03 15:15:19.426]
                              Read request for file <c1240-k9w7-tar.default>. Mode octet [17/03 15:15:19.427]
                              Using local port 49333 [17/03 15:15:19.428]
                              TIMEOUT waiting for Ack block #1  [17/03 15:15:34.480]
i used an ip address of 10.0.0.5 on my PC, but i'm not sure what the subnet mask will be.
please what am i not doing or doing wrong
5 Replies 5
Scott Fella
Boot up the AP and follow these directions, since you are having issues upgrading using the mode button... if this fails, then download the IOS image and rename the file again.
http://ciscosystems.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00809f0e94.shtml#task2
-Scott
i am not able to access the CLI command prompt, i'm getting this message
Mar  1 00:04:36.425: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
i'm supposed to assign an ip address range of 10.0.0.2 to 10.0.0.30 to my PC, in order to use the TFTP server to upload the IOS,  since the AP has a default Ip address of 10.0.0.1, but i don't know what the subnet mask will be
Ah... my bad... well try to use 3CDeamon TFTP and set your IP Address to 10.0.0.2 255.255.255.255.  If you still have an issue, then download the IOS image again and rename it... Cisco IOS release 12.3(7)JA or earlier.  Try a different laptop or machine also.
-Scott
now the AP is giving this error message
%Error opening  M|h¦` è (connection timed out)
Sounds like your TFTP server is not pointing to the location/folder of your IOS.
