Aironet-1562i-outdoor-access-point is not powering ON
Arjun@26
We have installed Aironet-1562i-outdoor-access-point one of my project, While installation it was getting power from the 4506-E Switch and it was registered with Wireless LAN Controller, but now the Access point is not getting power from the switch, connectivity is okay. what could be the reason??
marce1000
 - When you say connectivity is ok , that can mean anything , including the reverse ; can you try the connection with another AP and or POE-compatible device ?
 M.
Leo Laohoo
This is not helpful.
How could "connectivity is okay" but the AP is not getting any power?
adeebtaqui
Level 4
Level 4
Hi Arjun,
is this resolved? Were you able to rectifiy the poe issue for access point? Was it cable problem or less poe or access point interface issue?
